Jednak nie dochodzi do połowy tylko prawie do samego końca (dwa milimetry od końca) i wywala ten komunikat....
Edited by sebaxx93, 18 April 2013 - 13:07.
Posted 18 April 2013 - 12:08
Posted 18 April 2013 - 14:01
Posted 18 April 2013 - 14:17
18/010/2013 15:10:49 - INFO - <- This level is successfully initialized 18/011/2013 15:11:08 - INFO - Preparing files for flashing 18/011/2013 15:11:22 - INFO - Searching Xperia.... 18/011/2013 15:11:24 - ERROR - Please plug you device in flash mode 18/011/2013 15:11:25 - INFO - Searching Xperia.... 18/011/2013 15:11:25 - ERROR - Please plug you device in flash mode 18/011/2013 15:11:26 - INFO - Searching Xperia.... 18/011/2013 15:11:26 - ERROR - Please plug you device in flash mode 18/011/2013 15:11:27 - INFO - Searching Xperia.... 18/011/2013 15:11:28 - ERROR - Please plug you device in flash mode 18/011/2013 15:11:29 - INFO - Searching Xperia.... 18/011/2013 15:11:29 - ERROR - Please plug you device in flash mode 18/011/2013 15:11:30 - INFO - Searching Xperia.... 18/011/2013 15:11:30 - ERROR - Please plug you device in flash mode 18/011/2013 15:11:31 - INFO - Searching Xperia.... 18/011/2013 15:11:31 - ERROR - Please plug you device in flash mode 18/011/2013 15:11:32 - INFO - Searching Xperia.... 18/011/2013 15:11:33 - ERROR - Please plug you device in flash mode 18/011/2013 15:11:34 - INFO - Searching Xperia.... 18/011/2013 15:11:35 - INFO - Found at USB\VID_0FCE&PID_ADDE\5&C0BED81&0&1 18/011/2013 15:11:35 - INFO - Start Flashing 18/011/2013 15:11:35 - INFO - VER="R8A033";DATE="20120313";TIME="16:27:60"; 18/011/2013 15:11:35 - INFO - Flashing loader 18/011/2013 15:11:37 - INFO - PROT_VER="02";DATE="20091222";TIME="15:39:00";VER="R4A024";CXC="1226-2250";TYPE="S1_LOADER";UNIQUE_DEV_ID="4E7780B148CF087B637E911E0CBF236AC03A1F32";SEC_LOCK_STATUS="LOCKED";OTP_DATA="4BBD770047140402094804306EE24CEAF0C32000";IMEI="35942003869047";AID_VERSION="0004";EROM_AID="0001";LOADER_AID="0001";SW_AID="0001";CUST_AID="0001";SIM_LOCK_AID="0001";HWCONF_AID="0001";PROD_AID="0000";ACTIVE_LOADER_AID="0001";MAN_ID="002C";DEV_ID="00B3";SIN_VER="0001";AID_TAMP="NOT_TAMPERED";MAX_PKT_SZ="00010000";AUTH_LEVEL="NONE";AUTH_MET="0001";CARD_PRESENT="NO";LOADER_ROOT="S1_Loader_Root_f851";EROM_ROOT="S1_EROM_Root_b15e";SW_ROOT="S1_SW_Root_ac12";CUST_ROOT="S1_Cust_Root_5789";SIM_LOCK_ROOT="S1_SL_Root_f20d";HW_CONF_ROOT="S1_HWConf_Root_ee5d"; 18/011/2013 15:11:37 - INFO - Flashing kernel.sin 18/011/2013 15:11:39 - INFO - Flashing amss_fs.sin 18/011/2013 15:11:39 - INFO - Flashing dsp1.sin 18/011/2013 15:11:47 - INFO - Flashing fota1.sin 18/011/2013 15:11:48 - INFO - Flashing fota0.sin 18/011/2013 15:11:49 - INFO - Flashing amss.sin 18/012/2013 15:12:01 - INFO - Flashing cache.sin 18/012/2013 15:12:01 - INFO - Flashing system.sin 18/014/2013 15:14:36 - INFO - Flashing userdata.sin 18/014/2013 15:14:39 - INFO - Flashing finished. 18/014/2013 15:14:39 - INFO - Now unplug the device and power it on 18/014/2013 15:14:39 - INFO - Then go to application settings 18/014/2013 15:14:39 - INFO - turn on Unknown Sources and Debugging
Edited by not found, 18 April 2013 - 15:38.
Posted 18 April 2013 - 14:22
Posted 18 April 2013 - 14:40
Edited by sebaxx93, 18 April 2013 - 14:45.
Posted 18 April 2013 - 21:41
