K310 - problem z wgraniem softem od w200
17 replies to this topic
#1 OFFLINE   timmi
timmi
  • 863 posts
    • Time Online: 78d 5h 33m
Posted 25 May 2012 - 19:49
Cid 49 Welcome to SEtool2 ( LITE edition ) v 1.11
supported DB2010/DB2012 CID49/50/51/52, DB2020 CID49/51/52
Loaded 51 flash descriptors
if you like LITE edition - please visit www.setool.net and buy FULL.
FILE RECOGNIZED AS CUSTOMIZATION PACKAGE.
CDA:CDA102737/2
MODEL:Melinda Generic
VARIANT:CENT_EUROPE
LANGUAGE: EN
LANGUAGE: PL
LANGUAGE: CS
LANGUAGE: SK
LANGUAGE: HU
ChipID:8040,EMP protocol:0301
PHONE IS RED RETAIL PRODUCT
FLASH CID detected:49
Speed:921600
OTP LOCKED:1 CID:49 PAF:1 IMEI:35xxxxxxxxxxxxxxxxxx CERT:RED
PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0
LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738
Flash ID check:897E
Flash props sent ok
DETACH CABLE FROM PHONE.
REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
THEN PRESS "READY"
Trying to launch embedded bootloader...
INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2
Flash ID check:897E
Flash props sent ok
FOUND: R4EA031_CXC1250242_ORANGE_CO
Restore from:R4EA031_CXC1250242_ORANGE_CO
can't open file "D:\setool2lite 1.11\setool2lite 1.11\rest\R4EA031_CXC1250242_ORANGE_CO"
writing D:\SE\przerabianie_tuning_k310i_---_w200i\przerabianie tuning k310i --- w200i\W200_R4HA014_FS_CENT_EUROPE_RED52.fbn
CURRENT FLASH FILE CID:52
SSW uses complete hash, hash len is:2500
Will flash 125 blocks...
SSW loading returns:0
CSloader version:
SETOOL2 LITE  COMPACT_SEMC_FS_LOADER (FAT V26)
loader startup: executed
wrong response, break.
loader fs startup failed, that is fatal
Elapsed:276 secs.
not found: Wstawiłem znacznik code.
Posted 25 May 2012 - 20:32
Nie możesz wgrać softu przeznaczonego dla CID 52 do telefonu z CID 49 :) Możesz wgrać jedynie soft przeznaczony dla CID 49  :)
#3 OFFLINE   timmi
timmi
  • 863 posts
Posted 25 May 2012 - 20:39
Dziwne że na innych k310 się dało i mam jedną tak zrobioną i się da.
Posted 25 May 2012 - 20:47
Widocznie miały inny cid. Setoola nie oszukasz:
Więc zostaje Ci albo znalezienie stosownego softu albo crossflash w naszym serwisie online :)
#5 OFFLINE   timmi
timmi
  • 863 posts
Posted 26 May 2012 - 07:43
Wgrałem farem softa od k310 na początku ok a potem biały ekran.
#6 OFFLINE   bartq92
Posted 26 May 2012 - 08:29
Masz CID 49, wgrałeś soft właśnie pod ten CID ?
#7 OFFLINE   Gracjan44
Gracjan44
  • 43 posts
    • Time Online: 7d 11h 21m
Posted 26 May 2012 - 12:04
Przecież do K310i cid 49 zawsze wrzucało się soft od W200i R4HA014 cid 52 ;).
Posted 26 May 2012 - 13:12
Darmowym setoolem bez alternative security bypass? A to ciekawe :)
@ timmi - spróbuj przeflashować go w takim razie od nowa tzn. main + fs + custom, a nie tylko sam fs. Btw. wgraj soft generic, a nie Orange :)
#9 OFFLINE   jack79
  • 1,062 posts
    • Time Online: 77d 20h 17m
Posted 26 May 2012 - 13:13
Właśnie ,CID przy wgrywaniu soft ma znacznie chyba dopiero na DB2020, a tutaj jest to obojętne ,bo chyba nawet nie ma softu W200i z CID-em 49
Posted 26 May 2012 - 13:27
Bzdura. Cid zawsze miał znaczenie. Najniższy cid dla W200 to 50.
#11 OFFLINE   bartolinio3
Posted 26 May 2012 - 13:41
Czyli wychodzi na to, że dokonałem niemożliwego :rock:
Speed:921600
OTP LOCKED:1 CID:49 PAF:1 IMEI:[ciach] CERT:RED
Flash ID check:897E
Flash props sent ok
THEN PRESS "READY"
Flash ID check:897E
Flash props sent ok
FOUND: R4HA014_CXC1250719_GENERIC_ME
Restore from:R4HA014_CXC1250719_GENERIC_ME
can't open file "D:\Programy\SeTool_2_Lite_v1.11\setool2lite_1.11\rest\R4HA014_CXC1250719_GENERIC_ME"
writing D:\Telefony\softy\W200_R4HA014_MAIN_GENERIC_ME_RED52.mbn
SSW uses complete hash, hash len is:6340
Will flash 317 blocks...
Elapsed:207 secs.
Jurij: Usunąłem imei.
#12 OFFLINE   timmi
timmi
  • 863 posts
Posted 26 May 2012 - 19:46
Wgrałem softa w200 a wcześniej k310 i to samo sprawdzałem na 2 ekranach może ze starości płyta padać ?
#13 OFFLINE   Jurij
Posted 26 May 2012 - 20:02
Pokaż log identify.
#14 OFFLINE   timmi
timmi
  • 863 posts
Posted 27 May 2012 - 06:17
<p>welcome to setool2 lite edition v 1.08
Speed:921600
Flash ID check:897E
Flash props sent ok
OTP LOCKED:1 CID:49 PAF:1 IMEI:35xxxxxxxxxxxxx CERT:RED
FLASH CID:49 COLOR:RED
MAPP CXC article: R4EA031	 prgCXC1250466_GENERIC_DO
MAPP CXC version: R4EA031
Language Package:CENT_EUROPE
CDA article: CDA102737/2
CDA version: R1A
Default article: cxc1250474
Default version: R4EA031
Network LOCKED
Operator: 260-01
USERCODE:0000
Elapsed:9 secs.
Speed:921600
OTP LOCKED:1 CID:49 PAF:1 IMEI:35xxxxxxxxxxxxxxxxx CERT:RED
Flash ID check:897E
Flash props sent ok
THEN PRESS "READY"
Speed:921600
Embedded flashloader:
Flash ID check:897E
Flash props sent ok
FOUND: R4EA031_CXC1250466_GENERIC_DO
Restore from:R4EA031_CXC1250466_GENERIC_DO
CSloader version:
loader filesystem startup: executed
loader GDFS startup: executed
Processing script...
Will execute script now.
Phone detached
Elapsed:66 secs.
CDA:CDA102737/2
VARIANT:CENT_EUROPE
LANGUAGE: EN
LANGUAGE: PL
LANGUAGE: CS
LANGUAGE: SK
LANGUAGE: HU
Speed:921600
OTP LOCKED:1 CID:49 PAF:1 IMEI:35331501794707 CERT:RED
Flash ID check:897E
Flash props sent ok
THEN PRESS "READY"
Speed:921600
Flash ID check:897E
Flash props sent ok
writing C:\Users\Samsung\Downloads\W200_R4HA014_FS_CENT_EUROPE_RED52(1)\W200_R4HA014_FS_CENT_EUROPE_RED52.fbn
CSloader version:
Writing package...
Directory: tpa/preset/custom/
CONTENT_DOWNLOAD_HOOK.itm (2048)
Customize.xml (1122)
FM_PICTURES_HOOK_3.itm (10240)
FM_SOUNDS_HOOK_3.itm (10240)
FM_THEMES_HOOK_3.itm (10240)
FM_VIDEOS_HOOK_3.itm (10240)
GAMES_HOOK_3.itm (10240)
SETT_RINGTONE_HOOK_3.itm (10240)
Phone detached
Elapsed:146 secs.
Speed:921600
Flash ID check:897E
Flash props sent ok
THEN PRESS "READY"
Speed:921600
Flash ID check:897E
Flash props sent ok
writing C:\Users\Samsung\Downloads\W200_R4HA014_MAIN_GENERIC_ME_RED52(1)\W200_R4HA014_MAIN_GENERIC_ME_RED52.mbn
Elapsed:414 secs.</p>
#15 OFFLINE   jack79
  • 1,062 posts
Posted 27 May 2012 - 07:58
No to wygląda na to ,że też dokonałem niemożliwego ,bo też wgrałem soft od W200i z CID52 do K310i z CID49 :blink:
EDIT: Jurij mówię tylko tak jak jest i nie chcę się z tobą kłócić
Edited by jack79, 27 May 2012 - 15:14.
#16 OFFLINE   Jurij
Posted 27 May 2012 - 14:09
@ Timmi: Logi są w porządku, chociaż nie wiem czemu używasz tak starej wersji setoola. Jak dla mnie to usterka HW.
Niesamowite :) Próbuj tak z innymi modelami z platformy A1, nasz serwis online zawsze chętnie pomoże naprawić GDFS :)
#17 OFFLINE   timmi
timmi
  • 863 posts
Posted 27 May 2012 - 15:26
To ja nie wiem co robić lcd wsadziłem 2 i to samo soft wgrany to może coś wyczyścić ?
#18 OFFLINE   Jurij
Posted 27 May 2012 - 16:15
Jeszcze jedno pytanie. Teraz jak robisz identyfikację wersją 1.11 masz taki log:
Speed:921600
Flash ID check:897E
Flash props sent ok
CDA version: R1A
Network LOCKED
Operator: 260-01
USERCODE:0000
czy inny? Jeśli inny, to wklej w tagach code.
