J300 R2BC001 Patche | Patches
#1 OFFLINE   not found
  • 2,433 posts
    • Time Online: 107d 3h 30m
Posted 21 March 2012 - 13:35
Patche dla Sony Ericssona J300 R2BC001. Tylko patche, zero dyskusji ;)
Patches for Sony Ericsson J300 R2BC001. Only patches, no discussion.
;J300 SW-R2BC001
;Delete keyboard backlight
;(c) SiNgle
;(p) Maximys
44B6B4C2: 152D 0FE0
;J300 SW-R2BC001
;Delete operator logo
;(c) mobilefree
;(p) Maximys
44972894: 18F6B4F9 C046C046
449744F4: 16F684FB C046C046
;J300 SW-R2BC001
;Disable setupwizard on simcard change
;(c) den_po
;(P) Maximys
44973ABA: 04D1 0CE0
;J300 SW-R2BC001
;Delete time and date
;(c) mobilefree
;(p) Maximys
44972E76: 17F6C3FE C046C046
44972E80: 17F6BEFE C046C046
;J300 SW-R2BC001
;Faster long filename scrolling
;(c) SiNgle
;(p) Maximys
449B808C: FA21 4A21
449B818A: FA21 4A21
449B8280: FA21 4A21
449B82D9: 0B 05
;J300 SW-R2BC001
;Fast rewind long audio files
;(c) SiNgle
;(p) IronMaster, Maximys
44A9EB16: 6421 0121
;J300 SW-R2BC001
;Heap shift! more stability for patches!
;(c)den_po
;v.64k
;info 4 patchmakers: 4C297928...4C2A7927
;this info is firmware version dependent
+44000000
1150C: 306000200860B348 00270F60B34F81E1
11788: FFF77DFF 00F04BF8
11818: 2E2E2F736F757263652F686561702F68 064BC01A3060D81978E6044F00260670
11828: 6561702F686561706170692E63000000 401C491E7F1E002FF9D128E700000100
;J300 SW-R2BC001
;Phone works without SIM card
;Does not work: java, internet, Contacts...
;(c) Mobilefree
;(p) Maximys
446A8796: 0C1C 05E0
;J300 SW-R2BC001
;Whitelist to blacklist
;© the_laser
;(P) den_po, Maximys
448C72D2: BF41 FF43
;J300 SW-R2BC001
;Simplified list in Messages
;(c) Maximys
440F2CD4: 18720E4430B10F44587D1044 B42C0F44B42C0F44B42C0F44
440F2CE8: 68B00F44B8B00F44 B42C0F44B42C0F44
440F2CF4: 08B10F44 B42C0F44
;J300 SW-R2BC001
;Change function in Service Menu "Total call time" to "Navigation key counter"
;(c) Maximys
440FA604: F0A8 08A9
440FAAB0: F3 C2
;J300 SW-R2BC001
;Menu like K300
;(c) Maximys
440F2928: 63E3030062E3 CCE00300CDE0
440F2950: 182C 0C29
440F2B9C: 502B 182C
440F2C34: CAE00300CBE0 FFFF0300E5E0
440F3DD8: 0C290F44 00000000
;J300 SW-R2BC001
;Remove java security restrictions
;© the_laser
;(P) me-at,DenSoft,Maximys
44B8EDBA: 01D1 C046
44B8EDBC: 00 01
;J300 SW-R2BC001
;Remove "keylock" message
;(c)SiNgle
;(p) Maximys
44793EA8: F1F722FF C046C046
;J300 SW-R2BC001
;Remove message code master reset
;(c) Maximys
4411A6B0: 78 C0
;J300 SW-R2BC001
;Remove "nosound" message when turn on silent mode
;(c) Phenomen
;(p) den_po, Maximys
447964FE: 0AD1 0AE0
449742DC: 0021 14E0
4497B2B6: 0021 0EE0
;J300 SW-R2BC001
;Remove voice recorder beep
;(c)SiNgle,Maximys
440F19D8: 1E E0
;J300 SW-R2BC001
;Rename files with extensions
;(c)mobilefree.ru
;(p) Maximys
440E13B8: 2E00 0000
;J300 SW-R2BC001
;Vibra when connecting
;v. 1
;(c) IronMaster
;(p) Maximys
+44000000
8C40E8: 6920215C012902DB201C01F0DBFA 0148804703E0FFFF4154D044C046
D05440: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFB56423FA2252000121034D28690568
D05450: FFFFFFFFFFFFFFFFFFFFFFFF ED69A847FFBDFFFF20810F4C
;J300 SW-R2BC001
;Remove the message "Quick charge"
;(c) IronMaster
;(p) Maximys
44797A7D: B5 E0
;J300 SW-R2BC001
;Disable dimmer.
;Now lights will not be 15 seconds in the beginning to fade, and then another 5 seconds off.
;It will cut down after 20 seconds.
;(c) IronMaster
;(p) Maximys
44B6B556: E3F5AFFB C046C046
;J300 SW-R2BC001
;Time and date at the top of the screen.
;(c)mobilefree.ru
;(p) Maximys
44972E72: 0B21 0321
44972E7C: 0C21 0121
;J300 SW-R2BC001
;The Linear main menu
;The Menu will not be a grid of icons, but linear (like in file manager and etc.)
;(c) Maximys
440F2C0C: C0E00300C1E0 FFFF0300C0E0
440F2C34: CAE00300CBE0 FFFF0300CAE0
440F2D30: C4E00300C5E0 FFFF0300C4E0
440F2EF4: CEE00300CFE0 FFFF0300CEE0
440F2F1C: C8E00300C9E0 FFFF0300C8E0
440F3DFC: D0E00300D1E0 FFFF0300D0E0
440F3F38: BEE00300BFE0 FFFF0300BEE0
440F3F5C: BCE00300BDE0 FFFF0300BCE0
440F3F80: 51E2030052E2 FFFF030051E2
440E66E4: C6E00300C7E0 FFFF0300C6E0
440F296C: FFFFFF6F E7080000
440F2974: 8125B744 00000000
;J300 SW-R2BC001
;Remove "Warning: Loud ringtones could damage your hearing" message when you choose 7-8 volume level
;© Phenomen
;(P) Maximys
447A0938: 08DB 08E0
;J300 SW-R2BC001
;Dimmer timeout
;Instead of xxxx put: E803 - 1 s, D007 - 2s, 8813 - 5 sec, 1027 - 10 sec
;(c)SiNgle
;(P)Maximys
44B6B584: 983A xxxx
;J300 SW-R2BC001
;Improved work with files and folders
;(C) mobilefree.ru
;(P) Maximys
44C74564: 1422 8022; Increase the name of the new folder to 128 characters (was 20)
44C7407A: 1422 8022; Increase behalf rename folders up to 128 characters (was 20)
44C752D4: 1422 8022; increase peremeinovannogo file name up to 128 characters (was 20)
;J300 SW-R2BC001
;Size of the font in sms and a couple of other places.
;(C) SiNgle
;(P) Maximys
;00 small, 02 large, 01 default
444BEA6B: 01 00
;J300 SW-R2BC001
;Changing icons in video
;Remanufactured blue ribbon next to the video file on the icon with the extension
;Замена иконки у видеофайла
;Заменяется синяя лента рядом с видеофайлом на иконку с расширением
;(C) Joker XT
;(P) Maximys
44C7B638: 45 50
44C7B780: 45 42
Edited by not found, 05 January 2014 - 12:00.
: Dodałem więcej patchy
