( PROBLEM ) [XS++] K770I z CID51, podnoszenie do CID52.
13 replies to this topic
#1 OFFLINE   d!r3k
d!r3k
  • 6 posts
    • Time Online: 9h 59m
Posted 16 November 2011 - 01:48
Witam.
Mam taki problem, gdyż zakupiłem dzisiaj k770i z nietypowym CID'em, a mianowicie 51 i mam problem z podniesieniem go do 52 w XS++ 3.1 oraz 3.2 .
Problem wygląda następująco:
- odpalam XS++,
- klikam "Connect"
- podłączam telefon z wciśniętym "C"
- po chwili wyskakuje mi komunikat o tym czy podnieść CID, a więc klikam "YES",
- wszystko idzie sprawnie,
- po ponownym podłączeniu telefonu pojawia się ponownie komunikat o podniesieniu CID'a i tak w kółko.
Oto logi z XS++:
01:46:04| XS++ v3.1 (Darwin) Ready !
01:46:04| Executed on Microsoft Windows Vista
01:46:08|
01:46:08| Attempting to open the interface...
01:46:08|
01:46:08| TURN OFF PHONE!
01:46:08| Hold 'C' button on phone and connect phone NOW.
01:46:08| You have 30 seconds...
01:46:08|
01:46:12| Baseband ID: 9900
01:46:12| Protocol Version: 3.1
01:46:12| Warning: IMEI name does not match GDFS name (IMEI:NULL GDFS:K770)
01:46:12| ...using GDFS name
01:46:12|
01:46:12| Profiling SEMC phone...
01:46:12| Platform: DB2020
01:46:12| OTP CID: 51
01:46:12| EROM CID: 51
01:46:12| EROM Color: Red
01:46:12| IMEI: xxxxxxxxxxxxxx
01:46:12| Phone ID: K770
01:46:12| Region: VFE_LIVE_2
01:46:12| CDA: 1202-4294   R6A
01:46:12| Firmware Version: R8AC001
01:46:12| EROM: R3A099
01:46:12| Ready for operation!
01:46:15|
01:46:15| Sending db2020_cid01_prodid_p3j.bin...
01:46:15| Applet ID: 070129 0950 NGUCXC1250330_DB2020_PRODUCTIONIDLOADER_P3J
01:46:15| This is a PRODUCTION_ID loader
01:46:15|
01:46:15| Sending db2020_mem_patcher_cid51_r2a006.bin...
01:46:16| Applet ID: 061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
01:46:16| This is a MEM_PATCHER loader
01:46:16|
01:46:16| Sending db2020_red51_cs_r3a009.bin...
01:46:17| Applet ID: 070410 1557 HANCXC1250562_DB2020_CSLOADER_R3A009
01:46:17| This is a CHIPSELECT loader
01:46:17| Activating loader...
01:46:17| Activating GDFS...
01:46:33| This loader is UNLOCKED
01:46:33| Run GDFS-script...
01:46:33| Wrote 1 variables!
01:46:33| Read 0 variables to .\Backup\K770_xxxxxxxxxxxxxxxxxxxx_GDFSSCRIPT_OUTPUT_111016014633.script!
01:46:33| GDFS-Script was run successfully!
01:46:33| GDFS operation was successful
01:46:35| Disconnected... Unplug the phone
Z góry dziękuję za pomoc.
Pozdrawiam Dariusz.
#2 OFFLINE   Goomowiec
Posted 16 November 2011 - 08:27
Wydaje mi się że gdzieś tu tkwi problem, u mnie w k800 poszło bez problemu. spróbuj seusem aktualizować. podwyższy ci cid do 53 ale to w tym modelu żaden problem
#3 OFFLINE   d!r3k
d!r3k
  • 6 posts
Posted 16 November 2011 - 10:41
Próbowałem wgrać nowego softa SEUS'em, lecz bez skutku gdyż pisze, że telefon posiada najnowsze oprogramowanie.
#4 OFFLINE   bartq92
Posted 16 November 2011 - 11:20
Sprobuj podlaczyc z 2 i 5 zamiast c. Telefon dziala poprawnie ?
#5 OFFLINE   dante
  • 3,670 posts
    • Time Online: 153d 7h 21m
Posted 16 November 2011 - 16:00
A próbowałeś wgrać starsze oprogramowanie i potem podpiąć pod SEUSA ?
#6 OFFLINE   d!r3k
d!r3k
  • 6 posts
Posted 16 November 2011 - 18:16
barteq92, próbowałem lecz nic z tego, a telefon działa jak najbardziej poprawnie.
dante, właśnie w tym problem, że w ogóle nie mogę wgrać żadnego oprogramowania zarówno przez XS++ jak i SeTool'a.
#7 OFFLINE   Gracjan44
Gracjan44
  • 43 posts
    • Time Online: 7d 11h 21m
Posted 16 November 2011 - 21:29
Spróbuj xsem 3.2, jak nie to dodaj wypakowany ten plik
w misc kliknij write script i może podwyższy a jak nie to spróbuj z tym
  metoda ta sama, jak tymi plikami nie da rady to bez boxa nie pójdzie, chyba że jakimś kulan kendi, ultimate unlockerem, omniusem, jak wyrzuca błędy to pokazuj jakie.
#8 OFFLINE   d!r3k
d!r3k
  • 6 posts
Posted 16 November 2011 - 22:24
Gracjan44, niestety nie pomogło, oto cały log z SeTool'a:
Welcome to SEtool2 ( LITE edition ) v 1.10
supported DB2010
/DB2012 CID49/50/51/52, DB2020 CID49/51/52
Loaded 51 flash descriptors
if you like LITE edition - please visit www.setool.net and buy FULL.
ChipID:9900,EMP protocol:0301
PHONE IS RED RETAIL PRODUCT
FLASH CID detected
:51
Speed:921600
OTP LOCKED
:1 CID:51 PAF:1 IMEI:35223902872400 CERT:RED
FLASH CID
:51 COLOR:RED
LDR
:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
Flash ID check:897E
Flash props sent ok
ldr_on_ldr hdr
no ack (10)
CSloader uploading failed,exiting
Elapsed:62 secs.
XS++ 3.2 również nie idzie, jest to samo co w 3.1
#9 OFFLINE   Gracjan44
Gracjan44
  • 43 posts
Posted 16 November 2011 - 22:33
Z zadnym plikiem nie idzie?
#10 OFFLINE   d!r3k
d!r3k
  • 6 posts
Posted 16 November 2011 - 23:06
Z żadnym.
#11 OFFLINE   Gracjan44
Gracjan44
  • 43 posts
Posted 16 November 2011 - 23:29
No to juz darmowkami nic nie zdzialasz, jedynie wgrac soft ze zgodnym cda i seus lub zaplacic i robic zdalnie.
Posted 17 November 2011 - 00:01
View Postd!r3k, on 16 November 2011 - 23:06, said:
Z żadnym.
Napisz do mnie na gg: 1793684 gdzieś za 40-50 minut to Ci pomogę :)
#13 OFFLINE   d!r3k
d!r3k
  • 6 posts
Posted 17 November 2011 - 01:15
Problem rozwiązany.
Nie obeszło się bez box'a.
Serdecznie dziękuję za pomoc Jurij'emu.
Jeszcze raz dziękuję i pozdrawiam Dariusz.
#14 OFFLINE   Jurij
Posted 17 November 2011 - 01:16
Problem został rozwiązany, a temat zamknięty. W razie innych problemów, proszę założyć nowy temat. Wszelkie reklamacje/uwagi /opinie/sugestie proszę zgłaszać do Redakcji SonyEricsson-World.com poprzez PW.
